Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Remove door panel
Old 09-14-2012, 11:14 PM   #3
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 MX-5 and 09 Focus Coupe
Points 14,832, Level 78
Points: 14,832, Level: 78 Points: 14,832, Level: 78 Points: 14,832, Level: 78
Level Up 96% Completed
Forum Activity 10%
Activity: 10% Activity: 10% Activity: 10%
FF Reputation: 30 zetecDon Great Standing Member
Buy-Sell-Trade Rating: (50)
The hooked pick works best. But if you don't have one you can always use a shop towel/rag just as easily. Run the towel between the door panel and window crank. Then move the towel up and down and it will eventually catch the clip. Once the clip is disengaged, be sure to keep the clip. Usually after removing the clip I will pull the crank off and then instantly put the clip back on it. When you go to put the crank back on the clip will expand and then lock into place as you slide the crank back onto the post.
zetecDon is offline
