Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Shuts off while driving, restarts after cooldown
Old 09-14-2012, 07:32 PM   #7
MEJY1988
Fan#: 101883
What I Drive: 2006 Burgandy ZX5
Points 176, Level 3
Points: 176, Level: 3 Points: 176, Level: 3 Points: 176, Level: 3
Level Up 52% Completed
FF Reputation: 3 MEJY1988 Good Standing Member
Originally Posted by krank View Post
Did I mention that when the motor stops the clock and instrument panel turns off, and don't go on again when you turn the key until the motor catches, even though the starter turns over. Possible electrical, possible short, or maybe as suggested the coil? Any other suggestions?
Check all your battery connections, at both ends, positive and negatives/grounds, for corrosion and to make sure they are connected tight. Make sure battery is fully charged, then do a voltage check at the battery, first with engine off, should read around 12.5 Volts. Next check voltage at battery, with engine running, should be around 13.5 Volts.
I was a Shade Tree Mechanic, but had to cut down the Shade Tree to make room for the garage. Does this make me a Mechanic now?
MEJY1988 is offline
