Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - SYNC System Thread
Old 09-14-2012, 05:41 PM   #232
JoseC
Fan#: 103567
What I Drive: 2012 Silver SE hatchback
Points 11, Level 1
Points: 11, Level: 1 Points: 11, Level: 1 Points: 11, Level: 1
Level Up 21% Completed
Level up: 21% Level up: 21% Level up: 21%
FF Reputation: 1 JoseC Good Standing Member
Originally Posted by FordIVTteam View Post
You're welcome, Joe. You should be able to switch from USB to LINE IN, by giving the voice command LINE IN. I'm going to get a hold of a thumb drive and try this out on my display here. To clarify, when this happens, are music files from the USB actively playing?
Once I have played anything via the USB, there is no way to get the Line In to play unless the USB is unplugged first.
Each bullet below is an example, starting from the state of nothing plugged in:
  • Plug in USB and Line In. Switch from Radio to Aux. Line In plays/is available.
  • Switch from Radio to Aux, and using voice, switch to USB and play something. Then, using voice, attempt to switch to Line In. Get error message "Line in is unavailable when a device is connected to USB".
  • Switch from Radio to Aux, and using voice, switch to USB and play something. Switch back to radio. Then, using voice, attempt to switch to Line In. Get error message "Line in is unavailable when a device is connected to USB".
etc.
Thanks for looking into this.
Joe
JoseC is offline
