Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - wipers, window and speedometer problem help?
Old 09-14-2012, 05:26 PM   #4
DLQ001
Fan#: 80230
What I Drive: 2002 Silver Focus SVT
Points 512, Level 10
Points: 512, Level: 10 Points: 512, Level: 10 Points: 512, Level: 10
Level Up 24% Completed
FF Reputation: 1 DLQ001 Good Standing Member
Mine did the same thing, while driving the wipers would go intermittent, windows didn't work, cruise control would disengage. This happened at least every other day.
This is what I found wrong with mine:
Looking at the fuse box from the drivers side, it's the top left fuse. It's the #1 orange 40 Amp fuse.
Mine had a bad contact in the fuse box. I found it by pressing/wiggling the fuses until the wipers cycled (was actually at a job interview and needed to get the windows up). With the fuse out and looking at the contacts, one was a lot wider than any others in the box. I took 2 small screwdrivers and pushed them closer together. Haven't had any problems for over 3 weeks now.
Hope this helps you out.
Chris
DLQ001 is offline
