Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - post turbo build
Old 09-14-2012, 03:27 PM   #10
PSUrivie
PSUrivie's Avatar
Fan#: 67329
What I Drive: Boostin in the Mid-A
Points 8,749, Level 62
Points: 8,749, Level: 62 Points: 8,749, Level: 62 Points: 8,749, Level: 62
Level Up 99% Completed
Level up: 99% Level up: 99% Level up: 99%
FF Reputation: 16 PSUrivie Great Standing Member
Buy-Sell-Trade Rating: (11)
Your A/F seems to stay a little on the rich side @ idle. You sure you don't have any leaks anywhere? If not your tune might need tweeked a little.
What kind of turbo to you have installed? You're going to see a high oil pressure at a cold start. That being said, an incorrect diameter drain line can be causing you smoking issue. How do you have the drain line ran? pics?
FSWerks stg2 w/ water/meth; Cossie intake.
Massive Speed stg 2 cams in the works....
PSUrivie is offline
