Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - cam gear questions
Old 09-13-2012, 10:52 PM   #15
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
What I Drive: 2010 BMW 135i
Points 23,287, Level 93
Points: 23,287, Level: 93 Points: 23,287, Level: 93 Points: 23,287, Level: 93
Level Up 94% Completed
Forum Activity 13%
Activity: 13% Activity: 13% Activity: 13%
FF Reputation: 53 iminhell Excellent Standing Member
Buy-Sell-Trade Rating: (4)
Originally Posted by sgtsmasher View Post
im still lost on the whole how to actually tune them though. i mean i know you guys said to get them dyno tuned for best results.
what if i dont have a dyno to adj them correctly?
Then it'll be trial/error. If you can data log should help to verify your butt dyno. Watch for increases in load and air flow. Make a few different logs at the same settings and average them. Should reduce the error factor of a single WOT log.
would i just be screwing myself in the long run if i just took the stocks off and threw these on and tried adj them that way?
No.
You can run the gears in any location you want with no damage. [b]But it is the best idea to turn the engine clockwise by hand after major adjustments to make sure nothing's binding.
with the 5 bolt design do you loosen them up move the gear then tighten them again?
Yes.
Loosen the 5 bolts, use the center bolt to move the cam gear and hold it in place if need be, tighten all 5 lock bolts, then go back over then a second time to make sure you tightened them.
The bolts don't need to be gorilla TQ'd. Nice and snug is all you need, best guess, about 20 ft/lbs.
Over-tightening them will result in stripping the threads. And FWIW, 2 bolts still holds the gear in place,,, ya, I've stripped a few
13 years, 124,000 members and still no sponsored racing.
*your ad here*
*and here*......................................................................................................... *there's a wide open area here too*
*still space available*
iminhell is offline
