Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - An Interesting Article Regarding Tire Age
Old 09-12-2012, 10:48 PM   #13
jsr72
jsr72's Avatar
Fan#: 97393
What I Drive: MK III
Points 185, Level 3
Points: 185, Level: 3 Points: 185, Level: 3 Points: 185, Level: 3
Level Up 70% Completed
Forum Activity 4%
FF Reputation: 6 jsr72 Good Standing Member
Originally Posted by iminhell View Post
I'm wondering if it'd be better to rate tires based on weight vs pressure?
More mass will cause pressure to rise faster vs less mass. 35psi at 40*F isn't the same mass as 35psi at 90*F.
Or is the recommended pressures at some type of standard temp (72*F)? (if so that should be published more as well as a conversion for temp)
Recommended pressure (cold inflation pressure) is the pressure of the tire at ambient temperature without any heat build up due to usage.
Not following exactly what you are asking here.
jsr72 is offline
