Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - replacement 50,000 mile engine now ticks...
Old 09-12-2012, 05:08 PM   #9
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 23,458, Level 94
Points: 23,458, Level: 94 Points: 23,458, Level: 94 Points: 23,458, Level: 94
Level Up 11% Completed
Forum Activity 100%
FF Reputation: 78 felixthecat Excellent Standing Member
On 23's a great upgrade is to remove the balance shafts & install a plug in the oil feed hole to the balancer's. It removes 'bout 18-19lbs & 12-14lbs of rotating weight & on top of that you will found your motor now holds 6qtrs of oil. I just used a plug= freeze plug style & staked it into the feed hole & add a windage tray. Don't nick the pan or block w/ the razor blade when scraping off the rtv from the pan & block= take your time on that. You don't want come backs do you= In your case you don't want to redo your work do you? I don't think so. Enjoy the mod too.
felixthecat is online now
