Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Cooling Fan Temperature Set Point
Old 09-11-2012, 07:58 PM   #1
tp4pdb
Fan#: 94593
What I Drive: 2000 Blue Wagon
Points 135, Level 2
Points: 135, Level: 2 Points: 135, Level: 2 Points: 135, Level: 2
Level Up 70% Completed
FF Reputation: 1 tp4pdb Good Standing Member
I have a 2000 SPI that dropped a valve seat and has since been repaired. The cooling fans operate when the AC is on and also when the ECT is disconnected. The fans have not operated when the car is running and the AC is off. So far the highest engine temperature that I have seen while in diagnostic mode with the AC off has been 96 degrees C. I guess this would be expected if 96 degrees C does not exceed the temperature required to switch the fans on. Does anyone know what the set point temperature would be (in degrees C) in diagnostic mode to turn the fans on if the system is operating correctly?
Paul B - West Los Angeles
tp4pdb is offline
