Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - For Sale: WuNgUn's 2002 SVT/RS conversion
Old 09-11-2012, 05:23 PM   #1
WuNgUnSVT
WuNgUnSVT's Avatar
Fan#: 15803
What I Drive: '02 Sonic Blue SVT Focus, '03 Wagon
Points 5,683, Level 48
Points: 5,683, Level: 48 Points: 5,683, Level: 48 Points: 5,683, Level: 48
Level Up 67% Completed
Level up: 67% Level up: 67% Level up: 67%
FF Reputation: 34 WuNgUnSVT Great Standing Member
A lot of you have witness the progress with my car since new...I have pour sweat and blood and money into this
car! But I'm now 42, living in an apartment, decent job...but I think the time has come to say good bye.
I don't have the resources or the will to see this to the end, sadly...
So...
Asking $7500 CDN
One owner, bought new in Oct. 2002
Incomplete conversion in progress to European-only RS model Focus.
Notice the snug fitting (OE Ford) RS bumpers (imported from Germany), larger RS spoiler (also OE), extra-flared wide-body RS fenders (fiberglass replicas from OE sheet-metal).
Major servicing/repairs:
New timing belt, tensioner and idler at 220,000Km
Brand new VCT cam gear, VCT solenoid this spring
Recent maintenance:
Coolant flush with long-life coolant
Fuel filter
Copper spark plugs
Power steering and brake fluid flush
New clutch slave cylinder
New starter motor
New battery
New front O2 sensor
Modifications, recent:
CFM Blue silicone coolant lines
CFM silicone intake manifold couplers
Ported throttle body
Volant ram air intake
Ford Racing silicone spark plug wires
South Bend Stage I clutch/flywheel brand new
Turbo Tom's tune (Predator, included)
Fiberglass replica RS fenders/quarter panels (fitted)
S2 fiberglass replica RS side skirts (not fitted)
RS HVAC controls
Factory RS rear wing
Factory RS front/rear bumpers
RS fender liners, bumper splash shield
RS/O.Z.Racing 18" rims
RS steering wheel
RS rear hubs/disc/calipers (hubs used, calipers/rotors new)
10mm rear hub spacers
10mm front TRAK wheel spacers
Carbon fiber foglight surrounds
Full Prothane bushing kit front/rear
All new suspension hardware on rear
Rear subframe sandblasted and painted
Custom made delrin and aluminum shifter bushing
CFM hi-flow cat convertor
Fiberglass wrapped stainless exhaust header
Stop-Tech cross-drilled rotors up front
Other Modifications:
Custom made, push button starter electronics (not installed)
Viper Alarm
Metalized-tinted windows
Ebay halo projectors custom retrofitted with Infinity FX bi-xenon HID projectors with 'water clear', Retrofit Sources clear lenses
Custom-made LED from signals and fog lights (NOT LED bulbs!)
LED tail lights with custom LED amber signals (NOT LED bulbs!)
Full blue LED interior switch lighting
Custom-made gauge face (Km only)
Sonic blue gauge bezel and shifter surround
Tri-Ax short shifter
TWM weighted and engraved stainless shift knob
Custom made Delrin shifter cable bushings
Mazda RX8 leather-power-heated front seats
SVT embroidered floor mats
Dynamic Ford Racing dampers with SVT Intrax springs
ICE:
Water-cooled desktop computer (Gigabyte GA-MA790GP-UD4H with AMD Athlon II 235e X2 2.7 GHz CPU and 2GB of DDR1166 RAM)
OPUS 360 DC-DC PSU
8 inch widescreen in-dash touch screen
2X Asus Xonar 8 channel PCI sound cards
Linksys Bluetooth adapter
USB Wi-Fi adapter
Custom tire pressure-temperature sensors and CF app
Phigets USB sensor kit with temp-humidity-voltage-amperage sensors
OBDII USB interface (not working)
Infineon HD radio (also not working)
GPS USB reciever with licensed iGuidance 2009
Centrafuse 4.2 front end, licensed
Some licensed and trial CF apps
AudioMulch VST software running active 3-way crossover
CNC machined acrylic computer case and amp cover
Carbon-look false floor
Audio:
TRU T4.65 amps X 2 (8 channels total)
Alpine 2 channel sub amp
Aurasound 10 inch NS10-513-4A sub custom fitted in SVT sub box
Pioneer Premier TS-C720PRS 6.75 inch two ways X 4
Hand-wound VenHaus speaker wire
Hand-made TRS interconnects with Nakamichi jacks and RCA chassis mounted RCAs using THX certified Monster cable
Needs body work/paint to finish the RS model Focus, wide-body conversion.
Will sell without Car-computer, amps, speakers, PC hardware for $1500 less
An unbelievable amount of time and work and custom touches into this vehicle!
Ignore the high mileage. Engine and car meticulously maintained. Many new parts, major and recent maintenance work completed.
Drives incredible tight and very responsive. An absolute thrill for any car guy!
With F2 kit
As it looks now
...go threw your posts and see who can't spell retard...
WuNgUnSVT is offline
