Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - A/C problems
Thread: A/C problems
Old 09-11-2012, 04:33 PM   #13
Timthom62
Timthom62's Avatar
Fan#: 97579
What I Drive: 2012 Red Candy 5-Door SEL 303A
Points 5,440, Level 47
Points: 5,440, Level: 47 Points: 5,440, Level: 47 Points: 5,440, Level: 47
Level Up 45% Completed
FF Reputation: 5 Timthom62 Good Standing Member
The PCM controls air conditioning clutch engagement and the 12B37 update did change the PCM software a bit, but neither our SE with the manual a/c or our SEL with the DATC have exhibited this issue since the update back in May. They both start cooling within a minute or two of start.
My first question would be whether or not the clutch is engaging on start up or not engaging until the car is in gear.
As suss6052 points out, the vapor cycle air conditioning system relies on cooling air flowing across the condensor to cool the refrigerant. Even once the clutch is engaged, it takes time for the system to work up to operating pressure and for the cooling cycle to reach a point where you'd notice the difference at the vents. I know that on both of our cars, it takes considerably longer to feel the difference on a hot day.
Timthom62 is offline
