Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2010 ford focus gas pedal vibration
Old 09-10-2012, 01:23 PM   #6
sailor
Old Phart
sailor's Avatar
Fan#: 57268
Points 31,927, Level 100
Points: 31,927, Level: 100 Points: 31,927, Level: 100 Points: 31,927, Level: 100
Forum Activity 100%
Yup, and a "2010" should be "fly by wire" so the pedal vibration could only be a harmonic vibration caused by something else.....
The "cupped tires" certainly COULD be the actual issue, as they are likely to vibrate quite a bit!
When the alignment gets done, suspension joints, wheel bearings & brakes should be checked at the same time. Anything worn & loose could contribute to the problem - without knowing the mileage it's impossible to guess how likely that would be, but such a check for loose components is normal before wasting time trying to align something too loose to accurately align!
Luck!
sailor is offline
