Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Brake pedal goes to the floor sometimes
Old 09-10-2012, 01:08 PM   #5
sailor
Old Phart
sailor's Avatar
Fan#: 57268
Points 31,911, Level 100
Points: 31,911, Level: 100 Points: 31,911, Level: 100 Points: 31,911, Level: 100
Forum Activity 100%
as usual, it's hard to tell exactly what's going on from a distance....
Releasing & reapplying pressure to the brake pedal is usually considered "pumping", even if only the one stroke is required - and I think you mentioned it going to the floor.....
Was your steady pressure test done with the car running, or with it shut off??
(Brake vacuum booster &/or ABS can change your feel & how the system reacts....)
For example, you can have a QUITE firm pedal with the car off - but once it's running & the booster is functioning, the pedal might not feel so good....
ABS issues COULD come into play, that's why I mentioned the leakage found at the brake cyl. as a confirmation that you actually have an issue there before pulling it apart completely & replacing the master cyl..
luck!
sailor is offline
