Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2012 Ford Focus Euro Headlamp Availability
Old 09-10-2012, 01:04 PM   #198
MyThIc3LiTe
MyThIc3LiTe's Avatar
Fan#: 95163
What I Drive: 2012 Focus Titanium Blue Candy
FF Reputation: 4 MyThIc3LiTe Good Standing Member
Originally Posted by Tiger-Heli View Post
LED discussion is a bit off-topic but I can tell you this for certain with my 2002 Focus:
Installed LED replacements for the 194 bulbs in the HMSL and for the license plate light bulbs. Worked fine, no issues.
Bought some LED replacement bulbs for the taillights after the housing overheated and the incandescents were burning out every few months. Replaced taillight socket at same time.
Cruise control quit working - no indication why - just nothing happened when you pressed the button. Suspected the brake light switch and ended up destroying it, but was able to rebuild it. Swapped tail-light and turn signal bulbs. Cruise control worked fine again, but turn signals hyperflashed.
Load Resistors would have taken care of both problems, but need to be mounted to metal and away from plastic and not much of that near the tail-lights and more effort than I wanted to get into, so ended up going back to standard bulbs.
This is a Focus specific issue?
I changed my Veloster to full LED in the back and I've had no housing issues, no excess heat from my resistors, no cruise control issues what so ever.
As far as the resistors go, I got mine from VLEDs and they came mounted on a metal bracket so I just used some 3M and stuck them to the assembly itself
2012 Ford Focus Titanium Blue Candy Hatch 2009 Suzuki Swift+ - Traded in 2006 Lincoln Zephyr - Traded in
If you live in Edmonton, AB I would be more then happy to do a shoot with you!
MyThIc3LiTe is offline
