Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Does anyone know?
Old 09-10-2012, 09:40 AM   #3
Kipp
FocusFest Event Team
Kipp's Avatar
Fan#: 31300
Points 4,856, Level 44
Level Up 53% Completed
yes it is possible. as stated above you will need to run a power wire from the battery. you can get audio signal from the factory amp (i don't know if it's high or low level) and you might be able to get a turn on from it as well as long as it's a 12 volt turn on and not digital. if it's digital then you will need to run it from the ignition.
2010 Volvo C70
2011 Harley FLHTK
Midwest Crew #22
Kipp is offline
