Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Problems with the air conditioning
Old 09-09-2012, 11:10 PM   #3
SPI Tuner
Fan#: 47140
What I Drive: 2001, Red, LX
Points 90, Level 1
Points: 90, Level: 1 Points: 90, Level: 1 Points: 90, Level: 1
Level Up 80% Completed
FF Reputation: 1 SPI Tuner Good Standing Member
Well if the relay is bad find a relay that is in same wire set up in the car and try and get the AC to turn on. The main thing is to realize is, does the car pulsate when the relay is good and system is activated. So what could have happened is if the charge is low then its just a charge if the compressor doesn't kick on the it could be compressor related. If it cycles like tick...on then it low charge. From what I can deduce from your statement is that it has no charge. If it was off the car and you put a new compressor on then there is no AC charge to create what you need for Air Conditioning.
SPI Tuner is offline
