Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - broken exhaust manifold stud
Old 09-08-2012, 08:49 PM   #1
berndt
Fan#: 102080
What I Drive: 2002 Ford Focus SE
Points 796, Level 14
Points: 796, Level: 14 Points: 796, Level: 14 Points: 796, Level: 14
Level Up 96% Completed
FF Reputation: 1 berndt Good Standing Member
Cool broken exhaust manifold stud
Went to take the exhaust manifold out, to replace it. I suspected a cracked one. Sure enough, after zapping the bolts with some PB Blaster, and letting it sit for 10 or so minutes, I find a big crack almost all the way around the manifold between the 3 and 4th pipe.
The heat shield came off nice and easy. Hit the head studs with some PB Blaster, and let that sit a little while longer. Then those bolts came out real easy! Amazing, I might finish this in a couple hours, I thought. Then I got to the last bolt / stud, closest to the front of the engine, near the power steering pump. Put the socket on it, and gave it a VERY light tug. And it popped right off. It musta been broke already, or ready to go, since I didn't apply much pressure at all!
Looks like it broke off about a threads width into the side of the block. How on earth am I to get that out now? Or just put the new manifold back on and hope it'll work out with out it? 'cause Im really not in the mood for taking the whole mess out to get a square line on it to drill it out, and re-tap it. That'd include the power steering pump, serpentine belt, engine mount, coolant overflow......
Bryan Berndt
2002 Focus SE, auto, 2.0L SPI
berndt is offline
