Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2.5d engine swap
Old 09-08-2012, 07:11 PM   #32
VillageT
Fan#: 97061
What I Drive: 2005 Silver ZX3
Points 335, Level 6
Points: 335, Level: 6 Points: 335, Level: 6 Points: 335, Level: 6
Level Up 70% Completed
FF Reputation: 1 VillageT Good Standing Member
I have been asking around on this one and Tom appears to be correct about disconnecting the cam sensor once the computer has "registered" the location at initial start. Timing is done through the crank sensor.
What is not known is the result if the computer looses this registry. This can happen if the battery is disconnected for an extended period of time. The computer will go through an initial start process that sets the timing, injector settings etc. These settings go into a "keep alive" memory that the computer holds after the engine is shut down for the next start.
Village T
I am going to be off work for a couple days and I plan to test what happens after the "keep alive" memory is dumped.
VillageT is offline
