Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Vacuum Line questions
Old 09-07-2012, 08:05 PM   #10
inis
Fan#: 32050
What I Drive: 00 Zx2 s/r (yellow)
Points 3,047, Level 33
Points: 3,047, Level: 33 Points: 3,047, Level: 33 Points: 3,047, Level: 33
Level Up 98% Completed
Forum Activity 6%
FF Reputation: 1 inis Good Standing Member
Originally Posted by sporadic View Post
It makes sense and I've thought about that. I actually assumed there was already one in the 90* fitting that goes into the intake manifold until I cut it off the other day and found it to be hollow.
Have a link to a the check valve you use?
I use a honda check valve from the junkyard, they have a tan ring and are found on the firewall on the drivers side. I've tested them up to 30psi and 20in/hg with no leaks either way. Alot of srt4 guys are starting to use them too.
inis is offline
