Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - I'm annoyed ... (SYNC dead again)
Old 09-07-2012, 05:44 PM   #10
copernicium112
Fan#: 87742
What I Drive: 2012 Sonic Blue Ti Sedan
Points 1,565, Level 22
Points: 1,565, Level: 22 Points: 1,565, Level: 22 Points: 1,565, Level: 22
Level Up 65% Completed
FF Reputation: 4 copernicium112 Good Standing Member
Originally Posted by Raceredrudy View Post
I got to the fuses , and I found the right fuse (although I couldn't make out the "67" on it but I determined via owners guide it was the right one) under the glove box ---
Unfortunately I don't know much about car stuff and I have no idea how to remove a fuse or how to disconnect the battery ... Heck I couldn't even find the - !!!
I'm sending you a PM now FordTeam !
No worries Raceredrudy! If you are uncomfortable with any of it by all means take it to the dealership. That is what warranties are for.
If you still want to try the fuse route, there is a little red fuse puller clipped in under the cover of the fuse box under the hood. Use it to pull the fuse(s), wait about 10-15 minutes (that should be more than sufficient), and pop them back in.
Best of luck and report back (whichever route you choose to go) with the results/resolution.
.......here's a lockpick. It might come in handy if you, the master of unlocking, take it with you.
copernicium112 is offline
