Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2012 Ford Focus Euro Headlamp Availability
Old 09-07-2012, 01:38 PM   #189
Tiger-Heli
Fan#: 12379
What I Drive: 2002 French Blue SE Sedan
Points 2,736, Level 31
Points: 2,736, Level: 31 Points: 2,736, Level: 31 Points: 2,736, Level: 31
Level Up 91% Completed
FF Reputation: 4 Tiger-Heli Good Standing Member
You want to be a little bit careful with LED's on these cars.
On the 2002, the high-mount stop light LED's are fine - but using LED taillight bulbs makes the cruise control stop working (which is why you need the load resistors that you mentioned.)
http://www.corvettehid.com/HID%20Inf...0Bi-Xenon.html
Also - you are confusing auto-leveling with the high-beam indicator. The leveling parts that you mention are probably for European versions of the bulb assembly. The high-low is done by a shield which blocks the top of the bulb and is pulled up by a solenoid when high beams are selected.
Tiger-Heli is offline
