Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Open Grill Available?
Old 09-07-2012, 11:07 AM   #11
feta_mgp
feta_mgp's Avatar
Fan#: 88210
What I Drive: 2012 SGM Focus SEL
Points 3,601, Level 37
Points: 3,601, Level: 37 Points: 3,601, Level: 37 Points: 3,601, Level: 37
Level Up 68% Completed
Forum Activity 8%
Activity: 8% Activity: 8% Activity: 8%
FF Reputation: 7 feta_mgp Good Standing Member
Yes, the lower opening above the under tray but on top of the air dam is slightly more open, now how much of an effect on the cooling this is, I'm not entirely sure.
However I'm sure that if you had really wanted to put the standard bumper cover and grille panels on the car instead of the ST specific pieces you will have to either open the triangular grilles or dremel holes in the lower air dam to mimic the ST.
The remainder of the air induction portions of the grilles are the same just styled to look differently.
The main bulk of the air currently is coming in through the lower grille, between the area blocked occasionally by the shutter system and the lower openings in the front bumper cover/ air dam.
Right, that's exactly what I was suggesting.
Once upon a time I had:
2012 SGM SEL Sedan Job 1 BD 6/2011
FSWERKS Cool-Flo w/ ITG Filter | FSWERKS Stealth Exhaust | 17x7.5 Axis Sport XMX Graphite wheels | Eibach Sportlines on Ti Handling Pkg bits
feta_mgp is offline
