Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Thinking of attempting Timing Belt Change
Old 09-06-2012, 09:12 AM   #15
CotyM
CotyM's Avatar
Fan#: 85558
What I Drive: blue, y2k, 5spd ZX3, zetec inside
Points 1,007, Level 17
Points: 1,007, Level: 17 Points: 1,007, Level: 17 Points: 1,007, Level: 17
Level Up 7% Completed
FF Reputation: 3 CotyM Good Standing Member
Zetec timing kit, it makes it mostly idiot proof, if you use the kit. Just one thing to remember, if the timing bar does not fit in the cam slots and the crank is against the timing pin... your cams are upside down, just remove the timing pin, and turn the crank until the cams are mostly upright, re-insert the timing pin, and put the crank against the timing pin.
Also... To get the crank pully off of the crank was hard as the crank wanted to spin, so I put the motor in gear (Manuel transmission) and had my brother hold the brakes HARD) as I put an 18mm on the bolt and wit it with a hammer to break it lose...
The timing kit is $30 on advance auto's web site, Although no one in the store heard of it and said it must have been an online only deal... So I just ordered it.
And since you probably will take the plugs out might as well replace those to...
2000 Ford Focus US Spec Zetec 5 speed "Blue Dragon"
2000 Renault Clio 1.4 DOHC 5speed "Snap Dragon"
Hatch Nation #32
CotyM is offline
