Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Oil Leak: Dealer said Ford stated This is NORMAL
Old 09-06-2012, 06:55 AM   #20
BetaDnB
Rubber Side Down
BetaDnB's Avatar
Fan#: 87466
What I Drive: 2016 Race Red ST1
Points 3,060, Level 34
Points: 3,060, Level: 34 Points: 3,060, Level: 34 Points: 3,060, Level: 34
Level Up 7% Completed
Forum Activity 3%
FF Reputation: 17 BetaDnB Great Standing Member
Originally Posted by pozi240 View Post
I was aware of that TSB (Automatic Transmission Fluid leak), but, can't find the actual TSB to read it. Please post it up for everyone, especially if you're referencing it in a response, thank you. (I know, your response wasn't directed at me, I'm curious as well is all)
I found this info for you from this thread.
Originally Posted by bball40dtw View Post
I just got my Focus back from the dealership. The trans was slipping and the car was shuddering. I've had the TSB reflash of the transmission. Here is the description of the work done:
23001 WARR, CC D8CP 7052 Road test inspect driveline found dual clutch slipping due to leak at bellhousing. Check oasis for tsb's and ssm's found TSB 11-12-13. Remove trans and install new input shaft seals and new dual clutch. Perfrom adaptive learning and reroad test operation 111213A. Time 6.5 HRS
The parts to fix included:
2 seal assemblies
Clutch assembly/dual clutch packs
Various nuts and bearings
So far so good. The car is also getting better MPGs, but its probably to know for sure.
I also discovered this TSB list thread while searching.
Current- 2016 Race Red Focus ST1
Traded In - Sedan Revolution #249 - 2012 SE Sport - ╠╬╝ - Ingot Silver - 201A - K&N w/ snorkel delete - Blox Type R Knob
BetaDnB is offline
