Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Optimizing Accel and Decel
Old 09-05-2012, 08:32 PM   #25
dbenney
Fan#: 1195
What I Drive: 2012 Tuxedo Black SEL
Points 1,502, Level 22
Points: 1,502, Level: 22 Points: 1,502, Level: 22 Points: 1,502, Level: 22
Level Up 2% Completed
FF Reputation: 5 dbenney Good Standing Member
Originally Posted by kam327 View Post
But on more rural roads with a known stop sign way up ahead, neutral is the way to go.
You will always get better avg mpg coasting in N vs D or S... this is due to RPM. Coasting in N is like putting the clutch in on a manual trans. As soon as you put it into N your RPM drops to idle, where as if you leave it in D or S your RPM is matched per gear and vehicle speed programming. as you slow down the auto will downshift raising the RPM... the higher the RPM the lower the MPG and vice versa.
dbenney is offline
