Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Oil Leak: Dealer said Ford stated This is NORMAL
Old 09-05-2012, 03:14 PM   #6
Kabigon
Fan#: 88299
What I Drive: 2012 sterling gray Titanium
Points 5,736, Level 48
Points: 5,736, Level: 48 Points: 5,736, Level: 48 Points: 5,736, Level: 48
Level Up 93% Completed
Level up: 93% Level up: 93% Level up: 93%
Forum Activity 5%
FF Reputation: 11 Kabigon Great Standing Member
Originally Posted by Dysan911 View Post
I took my car in because there's oil seeping from between the Engine and The Transmission. Also a very metallic rattle when the car is in 6th gear and low RPM's. Like going up an incline at almost 40mph.
I just got a call and they said the tech couldn't reproduce the noise and the Oil leak is normal. Its not oil she said,. its some sort of factory fluid that they use during assembly and quite normal for it to leak.
I have officially HEARD THEM ALL now!. THank you FORD!.
I told her that It never did that before and she said that the Tech has had quite a few cases where they saw that same leak and contacted Ford and was told that was a Normal condition of this vehicle.
From TSB 11-12-13:
SERVICE PROCEDURE
1. Inspect the base of the transmission clutch housing for evidence of transmission fluid leak. Transmission fluid will be slick versus sticky. If the fluid leak is sticky and honey colored, it may be mistaken for engine oil or transmission lubricant. This condition may be caused by excessive rust inhibitor applied to the flywheel during manufacturing. Wipe clean the rust inhibitor from the transmission housing with Motorcraft® Metal Brake Parts Cleaner or equivalent.
Are you saying that the TSB is wrong or that you are sure that it wasn't rust inhibitor?
Kabigon is offline
