Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Those not happy with the 12b37 update
Old 09-05-2012, 09:31 AM   #70
Dysan911
Fan#: 95746
What I Drive: 2012 White, Focus Titanium
FF Reputation: 2 Dysan911 Good Standing Member
My Build is 12/11. Not that the battery pull has anything to do with this as I noticed this before the battery pull but today I dropped my car off for Service because at about 40mph or just under that when the tranny is in 6th. The slightest incline or if you push the gas pedal down just a little to bring the RPM's up it sounds like Im dragging a metal trash can lid under the front of the car. You can hear it over the radio.
Also there is oil seeping from between the area where the Engine meets the Transmission. Its odd though that it still seems to be shifting and holding fine but not as good as the first day I pulled the battery. I suspect the adaptive learning is starting to sneak back in.
Really wish there was an Adaptive Learning FUSE we could pull!. :)
Anyhow, considering I feel I have the worse Build ever, my rear main seals are probably shot and I'll probably need new clutches at this point.
So Far I've had service for:
1. Highway drift TSB
2. Front suspension Clunk TSB
3. 11-10-2 PCM update
4. 12B37 Update
5. MFT update 3.02
6. Rear driver door sticking
7. Bluetooth Mic Excessive ROad noise
8. Touch Handle Door unlock intermittent
9. transmission Oil leak
Yeah I doubt I"ll be keeping the car past 36k either.
Dysan911 is offline
