Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - How to remove center console?
Old 09-05-2012, 09:31 AM   #4
rambleon84
So mote be it
rambleon84's Avatar
Fan#: 51521
Points 9,644, Level 65
Points: 9,644, Level: 65 Points: 9,644, Level: 65 Points: 9,644, Level: 65
Level Up 98% Completed
Forum Activity 26%
Activity: 26% Activity: 26% Activity: 26%
Buy-Sell-Trade Rating: (15)
Originally Posted by 1gambit View Post
Also if you have a little useless cubby hole above the cup holders, pop that out and if I remember correctly there is a screw behind there too.
that one shouldnt be holding the console on though... I've taken mine off once or twice and it was fairly straight forward.
Try this as a guide to getting it off, the pictures and screw locations might be helpful:
How-To: SVT e-brake install
Also, try just taking your shift knob/boot off. See if you can look down in there and see the loose bolt first. If so, you might be able to fish it out with some long needle nose pliers. If not, then proceed to the full removal of the console.
The biggest trick is the e-brake itself. Pull it up as far as you can, then it will just be a matter of massaging the console out.
rambleon84 is offline
