Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Clutch troubleshooting basics?
Old 09-05-2012, 08:34 AM   #3
InfiniteWill
Fan#: 53238
What I Drive: 2007 Dk Toreador Red
Points 71, Level 1
Points: 71, Level: 1 Points: 71, Level: 1 Points: 71, Level: 1
Level Up 43% Completed
Forum Activity 5%
FF Reputation: 1 InfiniteWill Good Standing Member
Thumbs up Thanks for the info!
Originally Posted by Elizabeth View Post
Clearly: IF the clutch pedal is 'low' ONLY when The hydraulic device uses "O" rings for sealing. My bet is one of them is leaking just enough that after sitting, the fluid is all past the ring. with a few uses, it is sqeezed back, and does not leak 'enough' to cause problems while in use.
So it is 100% some leak in the hydraulic device which operates the clutch
A rebuild or new one will do.
Thanks for the scoop! I will certainly look into this ASAP. Can you recommend a good resource (Haynes, Chilton, web etc.) that might help me better understand the clutch system? I have done virtually no work on this car and I suspect with the miles racking up on it I will be more and more involved with it.
Will
InfiniteWill is offline
