Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - ST Parts UK
Thread: ST Parts UK
Old 09-04-2012, 09:45 PM   #5
Brabs_Weather
Fan#: 93741
What I Drive: 04 Ex Ltd, 08 Edge Ltd, 12 FF Ti
Points 731, Level 14
Points: 731, Level: 14 Points: 731, Level: 14 Points: 731, Level: 14
Level Up 31% Completed
FF Reputation: 2 Brabs_Weather Good Standing Member
Originally Posted by thehun View Post
That right there is the holy grail...no need for super expensive intakes..little searching got the specs
http://j-w-racing.co.uk/product.php/..._focus_st_mk3_
K&N XStreamŽ Top Universal Air Filters take performance to the next level with the addition of a filter within the filter's top adding more filter area for higher air flow and a longer service interval. The XStreamŽ Air Filter provides awesome air flow and outstanding filtration. When racing, in any environment, racers need all the protection and airflow they can get. K&N delivers. All K&N universal air filters are constructed with ultra-strong molded pliable rubber flanges which absorb vibration and allow for secure attachment and can also be stretched for up to 1/16 inch
Product Specifications
Product Style: Round Tapered Universal Air Filter
Base Outside Diameter: 6 in (152 mm)
Flange Inside Diameter: 2.75 in (70 mm)
Flange Length: 2 in (51 mm)
Flange Type: Centered
Height: 6.5 in (165 mm)
Top Outside Diameter: 5 in (127 mm)
Top Style: X-Stream
Top Material/Finish: None
Filter Material: Cotton Gauze
Filter Re-Oiling Amount: 1.16 oz (34 ml)
Weight: 1.4 lb (0.7 kg)
Product Box Length: 6.31 in (160 mm)
Product Box Width: 6.31 in (160 mm)
Product Box Height: 10.19 in (259 mm)
http://www.knfilters.com/search/prod...x?Prod=RX-4960
it is actually http://www.knfilters.com/search/prod...x?Prod=RX-4870
it is 6.5 length which is a .25 inch longer than the stock one so the adapter ring supports it. One can make it from aluminum or reuse the plastic end of the stock filter.
White Platinum Tricoat Metallic
2012 Ford Focus Titanium
Handling Package Nitto Motivo's
Borla Exhaust with UltraQuiet resonator
K&N X-4870. Steeda RSB
Brabs_Weather is offline
