Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - The car you love to hate....the build thread.
Old 09-04-2012, 05:51 PM   #169
1hotfocus
1hotfocus's Avatar
Fan#: 82813
What I Drive: 00' sedan
Points 6,372, Level 52
Points: 6,372, Level: 52 Points: 6,372, Level: 52 Points: 6,372, Level: 52
Level Up 11% Completed
FF Reputation: 7 1hotfocus Good Standing Member
Buy-Sell-Trade Rating: (21)
Alternators are different between zetec and spi.. unfortunately.
You will also need the coolant hoses and the little pipe that mounts above the radiator for a zetec.
A new power steering pump and line to the rack is required.
The Zetec also requires a different cat converter & flex pipe.
You will also need a new throttle cable and the positive battery cable to the starter, which goes on to the alternator on the Zetec.
The vacuum line to the power brakes is also different. You will need the small vacuum lines that connect to the intake manifold. Also the fuel line to rail hose assembly is different.
In addition to the passenger side motor mount, you also need the bracket that it bolts to.
Good luck
Sent from my SAMSUNG-SGH-I717 using FF Mobile
Give rep if youve been helped :)
1hotfocus is offline
