Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Official ST Part Numbers Thread
Old 09-04-2012, 12:23 AM   #8
20Focus13's Avatar
Fan#: 92454
What I Drive: 2013 Focus ST ST3,2012 GT500 750HP
Points 392, Level 7
Points: 392, Level: 7 Points: 392, Level: 7 Points: 392, Level: 7
Level Up 84% Completed
Level up: 84% Level up: 84% Level up: 84%
Forum Activity 15%
Activity: 15% Activity: 15% Activity: 15%
FF Reputation: 1 20Focus13 Good Standing Member
Here are some specs out of the ST manual. Besides the struts, it looks like Ford made changes to the knuckles and stabilizers too.
•2.0L GTDI EcoBoost I4 engine
•Over boost function for increased torque
•Electronic over-rev function with 6800 rpm redline
•ST tuned 2.5 in. center exit exhaust system
•Getrag-Ford MMT6 6-speed manual transaxle
•Active sound symposer
•Variable ratio steering
•Modified front suspension knuckle for improved wheel end geometry
•Cast rear knuckle (improved stiffness) and alternative anti-roll-bar
mounting for improved efficiency
•ST tuned springs and dampers
•Increased diameter (320 mm) front brake rotors and unique calipers
with ST tuned pad formulation front and rear
•Enhanced torque vectoring control with cornering under steer control
•ST tuned electric power assisted steering with torque steer compensation
•AdvanceTrac stability enhancement system with three modes:
Normal, Sport and Disabled
•18in.x8in.55mm offset aluminum ST Wheels
•P235/40-18 directional Goodyear Eagle F1 tires
•ST engineered front and rear fascias and rear wing
Focus ST Unique Features
20Focus13 is offline
