Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - SVT P0125 code
Thread: SVT P0125 code
Old 08-30-2012, 07:02 PM   #12
IH84DZ
Fan#: 101801
What I Drive: 03 CD silver SVT 5 door
FF Reputation: 5 IH84DZ Good Standing Member
This code means your car hasn't reached 180* or so in a specified time. It means your thermostat is stuck open 99% of the time. You could also have some resistance in the ECT sensor or wiring. More temp = less resistance with thermistors so more resistance would make the PCM think it was a lower temperature.
The sensors measure poorly in air as well so a low coolant level may cause an air bubble to form near the sensor...but these aren't difficult motors to "burp".
I only have luck with Ford thermostats. I've had two Autozone stats stick open on me. I find the oil temp runs cooler than the coolant temp when this happens. Unless I really rev the motor the oil temp always was a little lower on the gauge.
IH84DZ is offline
