Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2.5d engine swap
Old 08-30-2012, 02:51 PM   #10
Fernando_221
Fan#: 79468
What I Drive: '06 ZX4 2.0L Dtec, '11 MK2.5 2.0L
Points 2,561, Level 30
Points: 2,561, Level: 30 Points: 2,561, Level: 30 Points: 2,561, Level: 30
Level Up 74% Completed
Forum Activity 3%
FF Reputation: 3 Fernando_221 Good Standing Member
Originally Posted by VEGAS View Post
this was from Tom back in April
"I have made a prototype VCT Elim for the 2.5 now and working on making everything a bolt in for the 2.5L"
Also
"Ford 2.5 out of the Fusion is the best swap"
and this was also posted by someone else
"I believe the 2.5 comes standard with VCT. Which means you will have to get an ECU to go with the engine. And since it isn't in a Focus, that will make the swap even harder."
You can throw a set of stock cams and pulleys (after market/stock cams from head without vct) and keep the vct solenoid unplugged. The 2.5 head accepts non-vvt cams, but vvt will not work, if you don't care about vvt no problem.
This is what I'll do. I can post some pictures of the 2.5 block.
Fernando_221 is offline
