Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - NO indicator for winshield wiper fluid
Old 08-30-2012, 01:26 PM   #72
Timthom62
Timthom62's Avatar
Fan#: 97579
What I Drive: 2012 Red Candy 5-Door SEL 303A
Points 5,440, Level 47
Points: 5,440, Level: 47 Points: 5,440, Level: 47 Points: 5,440, Level: 47
Level Up 45% Completed
FF Reputation: 5 Timthom62 Good Standing Member
Actually, if you could just get access to the electrical connector for the washer fluid switch/level sensor, it's only a two wire system and it should be pretty easy to simulate a 'closed' switch. Just using a bit of wire as a jumper between the two pins of the connector should cause the message to appear.
Unfortunately, the access is the issue, as you pretty much have to come from underneath the car or remove the right headlight (and deal with the possible adjustment issues there). The level sensor is on the outer side of the tank just back from the washer fluid pump.
Timthom62 is offline
