Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Broken Rear Control Arm Adjuster Bolt (used for alignments)
Old 08-29-2012, 10:43 PM   #2
elsolo
elsolo's Avatar
Fan#: 96835
What I Drive: 2007 white ZX3
Points 3,144, Level 34
Points: 3,144, Level: 34 Points: 3,144, Level: 34 Points: 3,144, Level: 34
Level Up 63% Completed
Level up: 63% Level up: 63% Level up: 63%
FF Reputation: 18 elsolo Great Standing Member
The pics are for the UPPER control arm, you need the lower as seen in the links at the bottom of your post. The lower has the bushings that seized to the adjuster bolt. You could do the prothane bushings that you linked to, but the labor to press them in/out of the control arms will make the job considerably more expensive.
elsolo is offline
