Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Flash memory card or USB stick to play WMA files 2012 Titanium
Old 08-27-2012, 07:16 PM   #13
lifespeed
Fan#: 102024
What I Drive: '12 Ford Focus Ti, 04 Merc Marauder
Points 988, Level 16
Points: 988, Level: 16 Points: 988, Level: 16 Points: 988, Level: 16
Level Up 88% Completed
FF Reputation: 2 lifespeed Good Standing Member
256GB flash drive fails
So I bought a 256GB SSD (solid state drive) with USB 3.0 interface. Yes, I'm sure the 2012 Focus MyFord Touch only supports USB 2.0, but USB 3.0 is backwards-compatible.
Unfortunately, I find the 256GB Kanguru SSD does not work in the Focus!!
I formatted it to FAT32 and copied over several folders of WMA lossless music. Doesn't even see the drive. When I plug in a 4GB thumb drive with WMA music it sees it fine.
Any idea if there is something I can do to make this drive compatible with MyFord Touch? I thought FAT32 filesystem was the extent of what is needed. The Kanguru SSD appears to power up fine plugged into MFT . . .
Edit: my USB 2.0 ports on my PC work fine with this USB 3.0 drive, as expected.
lifespeed is offline
