Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Hughesy's 2nd Gen Duratec Turbo Build
Old 08-26-2012, 09:49 PM   #67
Hughesy27
Hughesy27's Avatar
Fan#: 84331
What I Drive: 2010 blue se
Points 1,977, Level 26
Points: 1,977, Level: 26 Points: 1,977, Level: 26 Points: 1,977, Level: 26
Level Up 77% Completed
FF Reputation: 1 Hughesy27 Good Standing Member
A little update. I went ahead and installed the intake manifold. Not gonna lie, was a bitch to install. Advice for those wanting to do it, drop the fan down and it helps to remove the power steering pump Res. Bottom bolts were a pain to get to. But I got it done and also went ahead and did the pcv delete like sporadic did. I was just mocking up some piping and decided just to go for it. There is a PDF out there with instructions on how to do the install from cosworth. Not really sure the stipulations on that so if you are interested, pm me and I'll send it to you if you want. I start classes again tomorrow so busy week ahead but plan on mounting the intercooler so when the time comes just bolt it up. So far everything looks like it will fit perfectly. Will find out if I have to tweek the hotside or not. Will keep you posted. Also, I'll post some pics of the manifold.
Sent from my LG-P925 using FF Mobile
Hughesy27 is offline
