Old 08-26-2012, 05:15 AM   #1330
6769MOPARS
6769MOPARS's Avatar
Fan#: 86108
What I Drive: PB Focus ST2 and 67 426 Hemi GTX
Points 571, Level 11
Points: 571, Level: 11 Points: 571, Level: 11 Points: 571, Level: 11
Level Up 43% Completed
FF Reputation: 1 6769MOPARS Good Standing Member
Originally Posted by TrooperSeven View Post
I should of explained it better I know. The water only comes in the lower side of the carpet ( about 6 inches up the lower side ) and where the spare tire sits is full of water. he said he fixed it. It took about a month for the problem to come back. So I'm thinking they used some kind of sealant that failed. I think they need to replace the right wheel well completely for a proper repair.
That's OK. I am trying to visualize water spraying up into the rear hatch. If there is a body plug in the spare tire area, you can remove it to drain the water.
If they used a silicone sealer along the seam, that will work, but, what they probably need to do is weld the seam. It sounds like they know where the leak is and that they need to do a proper repair.
Please escalate to the Ford Rep on the forum. This should be a relatively easy repair.
6769MOPARS is offline
