Old 08-26-2012, 06:00 AM   #1328
6769MOPARS
6769MOPARS's Avatar
Fan#: 86108
What I Drive: PB Focus ST2 and 67 426 Hemi GTX
Points 571, Level 11
Points: 571, Level: 11 Points: 571, Level: 11 Points: 571, Level: 11
Level Up 43% Completed
FF Reputation: 1 6769MOPARS Good Standing Member
Originally Posted by TrooperSeven View Post
when I wash the car it doesn't leak. it's coming in from below when I drive it on wet roads. The dealer even confirmed that.
In that case, I'd remove everything from the rear hatch area and have someone ride back there when the roads are wet - maybe the tech? If the dealer acknowledges the problem, it is documented and they should fix it.
Maybe even use a high pressure hose in the wheel wells to find the source of the leak.
Or - with everything removed from the hatch, spray water (gently) along all the seams and watch where water drips out the bottom.
6769MOPARS is offline
