Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - How to fix light scratches/ Blemishes on nterior trim?
Old 08-24-2012, 12:06 PM   #11
xpeterbilt387x
xpeterbilt387x's Avatar
Fan#: 54461
What I Drive: 14' PB ST2
Points 3,820, Level 39
Points: 3,820, Level: 39 Points: 3,820, Level: 39 Points: 3,820, Level: 39
Level Up 14% Completed
Level up: 14% Level up: 14% Level up: 14%
FF Reputation: 3 xpeterbilt387x Good Standing Member
Originally Posted by Fresh1 View Post
Maybe they can be fixed the same way as very light scratches in the windshield (the kind you can only see when light hits it from a certain angle). I'll try this suggestion too for a couple of light scratches on my dash info display screen, which were there when I got the can new ...
"Q: Scratching the Surface I've got some light scratches in my windshield. My nail doesn't catch in them, so they're not deep, but the usual Windex is not having an effect. Can I buff these out? How?
A: There are two ways to address light scratches in glass. The easiest is to fill the scratches with an acrylic scratch remover, which is applied as a liquid and dries hard and transparent, hiding the damage by filling the scratches chemically. For deeper scratches, the most popular fix is buffing the glass with cerium oxide, a popular glass, ceramic and metal polish with very low abrasiveness—it's widely used in jewelry and ceramics. Add water to the fine powder and make a slurry the consistency of Elmer's Glue, then cover the damaged areas with the paste. Using a drill with a hard rubber polishing wheel attached, apply firm pressure to slowly grind the surface smooth. To make things a bit easier, mark the location of the scratch on the other side of the glass so you can keep track of where you should be working. It may take a while, but keep the paste moist and add more cerium oxide as needed, and the result will be a smooth, scratch-free surface."
http://www.popularmechanics.com/cars...our-windshield
Some interesting stuff in that!
xpeterbilt387x is offline
