Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Transmission Shaking To/From 1st Gear
Old 08-22-2012, 04:45 PM   #61
noahsfocus
noahsfocus's Avatar
Fan#: 90974
What I Drive: 2015 White ST3
Points 534, Level 10
Points: 534, Level: 10 Points: 534, Level: 10 Points: 534, Level: 10
Level Up 68% Completed
FF Reputation: 5 noahsfocus Good Standing Member
Originally Posted by Nickrand View Post
Wanted to add to this topic by saying that my 2012 Focus with dual-clutch transmission (build date December 2012) also started to shudder and hesitate upon acceleration while going into 2nd gear. This started after 10,000 miles. It only did this on a warm engine (after several starts and stops). It was fine when shifting into higher gears.
Turns out that the clutch was defective. It wasn't releasing correctly. My Ford dealer called the Ford service hotline and they confirmed that this is an identified problem on some Focuses. Replacing the clutch was the only solution. They got a new clutch kit from Ford and completed the repairs in a day.
Just got my Focus back today and the problem is resolved.
Any updates on your fix? I suppose all is well ... your fix gives us hope that this issue can be corrected!
I guess with the problem only being noticeable after warm up that would explain why people are having a hard time getting this diagnosed properly, as mentioned by BPEW584.
It's not the hesitation going into 2nd so much but the clutch actually slipping, causing shaking/shuddering that can be very noticeable at times, about half way through 1st gear that I see as my problem. Hoping the service dept will agree and I'm pretty sure they will. I may have to pull in with the clutches warmed up amd take the trans tech for a ride along to demonstrate the failure if they don't see it on the first check.
Originally Posted by jagreene View Post
I am having the same problem! Ford definitely knows about it. I have talked to several dealers and they basically said there is "no fix" and "it is what it is".
Keep trying, eventually they have to listen. Try taking the tech for a test drive in your car to demonstrate the problem then request a test drive with him in a new car on the lot to compare with. Hoping there is a difference of course which there should be.
Nickrand got his fixed so certainly there is a fix available.
noahsfocus is offline
