Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Sound Upgrade Almost Done (Premium Really??)
Old 08-17-2012, 09:12 PM   #12
Fan#: 99616
What I Drive: 2012 silver focus S
FF Reputation: 1 JL330 Good Standing Member
Originally Posted by aablakersrf View Post
Well your choice is pretty clear then, however, your install of the MS8 will be a little different from mine because you need to get the wires that go in and out of the MS8 from the front of the car, passenger seat consol area. If you are going to amp everything eventually, you will want to think about placement of the MS8. Mine was easy as the factory amp is exposed and I just attached wires. You might have to run some speaker wire up and down the car (which shouldn't be bad, just hide them under the runners).
What are you looking for your head unit to do?
I didn't really want a head unit at all but considered that route because line out converters aren't much and I thought it would be my only option. If I was going that route though, I wanted navigation and the works. Things I don't need when the main goal is just sound quality and I'd prefer to keep the stock look.
JL330 is offline
