Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Transmission Shaking To/From 1st Gear
Old 08-17-2012, 07:32 PM   #42
suss6052
suss6052's Avatar
Fan#: 95752
Points 12,333, Level 72
Points: 12,333, Level: 72 Points: 12,333, Level: 72 Points: 12,333, Level: 72
Level Up 71% Completed
Forum Activity 5%
Buy-Sell-Trade Rating: (3)
Originally Posted by Nickrand View Post
Yes, the shudder only happened from 1st to 2nd I believe. I'm not a car expert. It happened between 20-30 mph when accelerating from a stop. I'm assuming this is 2nd, but could be 1st. No shuddering at higher gears.
Not sure about TSB 11-12-13, but I had the latest TSB performed a month ago, so I'm pretty sure I was updated on everything before I took it in for the shudder problem. Before they replaced the clutch, they also did a DCT reset/re-learn thing which they confirmed didn't fix the problem. It was a bad clutch that wasn't releasing properly at that specific gear.
You can be in fourth gear down to 20 mph, so it could have been between 3rd and fourth at least if it was at low rpm on light throttle, but unless you were at higher rpm when it happens how are you sure that you were in first or second at 20-30 mph?
suss6052 is offline
