Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Transmission Shaking To/From 1st Gear
Old 08-17-2012, 06:20 PM   #41
noahsfocus
noahsfocus's Avatar
Fan#: 90974
What I Drive: 2015 White ST3
Points 534, Level 10
Points: 534, Level: 10 Points: 534, Level: 10 Points: 534, Level: 10
Level Up 68% Completed
FF Reputation: 5 noahsfocus Good Standing Member
Originally Posted by Nickrand View Post
Wanted to add to this topic by saying that my 2012 Focus with dual-clutch transmission (build date December 2012) also started to shudder and hesitate upon acceleration while going into 2nd gear. This started after 10,000 miles. It only did this on a warm engine (after several starts and stops). It was fine when shifting into higher gears.
Turns out that the clutch was defective. It wasn't releasing correctly. My Ford dealer called the Ford service hotline and they confirmed that this is an identified problem on some Focuses. Replacing the clutch was the only solution. They got a new clutch kit from Ford and completed the repairs in a day.
Just got my Focus back today and the problem is resolved.
Glad it was fixed! Looking like this will need to be done sooner or later to mine as well. It still works pretty good and sometimes doesn't even slip, usually under really light or really heavy acceleration it works fine. But from a stop with medium acceleration; about half way thru 1st gear it will start slipping and I will feel the shudder again right before shifting into 2nd and occasionally it will have a strong lurch or harsh shift into 2nd. I havn't noticed if it's worse after warm up ... seems like it happens randomly all the time regardless of hot or cold. The rest of the gears shift normal but I get a random lurch once in awhile in the upper gears as well but no slippage that I can tell.
I will have it looked at by the dealer to see if they can confirm there is a problem.
noahsfocus is offline
