Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2nd time around, need some ideas, SPI will not stay running
Old 08-17-2012, 11:11 AM   #2
MEJY1988
Fan#: 101883
What I Drive: 2006 Burgandy ZX5
Points 176, Level 3
Points: 176, Level: 3 Points: 176, Level: 3 Points: 176, Level: 3
Level Up 52% Completed
FF Reputation: 3 MEJY1988 Good Standing Member
IMO, if you have 35 psi at fuel rail, but need to dump fuel into throttle body to get it started, you either have a clog in the fuel rail, faulty injectors, or the injectors are not firing. You can get noid lights to check the voltage at the injectors. I would start there.
Good luck.
MEJY1988 is offline
