Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - CFM Intake boots- Warning/tip
Old 08-16-2012, 10:48 AM   #6
TommyTooHi
TommyTooHi's Avatar
Fan#: 90859
What I Drive: 2004 Red Focus SVT
Points 1,292, Level 19
Points: 1,292, Level: 19 Points: 1,292, Level: 19 Points: 1,292, Level: 19
Level Up 92% Completed
FF Reputation: 1 TommyTooHi Good Standing Member
yup yup and yup
Originally Posted by BigRed03 View Post
havent had an issue since i put them on in 2009....
you sure the boot and/or clamps are seated properly when you install?? Did you pull the fuel rail to get the most access? I remember getting the #4 cyl (drivers side) on last and it was the most difficult. the bottom edge didnt want to go around the upper intake (part not attached to head). I put the couplers on the head side first, tightened those clamps and then started with #1 and worked my way across.
yup, and everything was snugged up tight, even new o-rings on the injectors for piece of mind...
I know it sounds like I moofed somewhere, but it's pretty easy to tighten hose clamps.
-T_T
Aw, heck - you mean what I know...
Mods: Caffeinated nut behind the steering wheel
TommyTooHi is offline
