Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Roush 00-04 Turbo Kit
Old 08-11-2012, 10:13 PM   #36
ktwelsch
FoFo Lover.
ktwelsch's Avatar
Fan#: 30202
What I Drive: 2012 Mazda 3i
Points 8,093, Level 60
Points: 8,093, Level: 60 Points: 8,093, Level: 60 Points: 8,093, Level: 60
Level Up 72% Completed
FF Reputation: 9 ktwelsch Good Standing Member
Buy-Sell-Trade Rating: (27)
Originally Posted by focusmaniaczx3 View Post
dirt/gravel roads wont hurt anything with it so long as your run an air filter. might have to worry about rocks hitting the intercooler but if you run a screen in front of it like you should you wont have to worry about that either.
what you might need to complete the installation is maybe another header gasket because im not sure if i would reuse that one or not, i leave that to your judgement when you see it in person.
you NEED a tune hands down, no buts about it. contact tom ASAP so you can have your xcal and have everything ready to go before you start the installation.
you might need a way to feed oil to the turbo. i see it has oil feed lines now but im not sure from the pictures where it feeds FROM. a good place is directly from the oil pan. tom sells oil pans that are tapped and ready for those oil feed lines. and if for whatever reason he doesnt have any, it really isnt hard to do yourself or have someone do it for you.
boost controller
wideband a/f ratio gauge
you may or may not want to run a diablo MAFia. its basically a glorified MAF sensor harness extension lol
i cant think of anything else its lacking. those are really little things that it lacks, this is a very complete kit
The oil feed line has a screw mounted to it that taps into the back of the engine block. Screws in to the block above the starter with a 11mm crescent wrench.
SEDAN REVOLUTION #42 Baby!
ktwelsch is offline
