Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Poor Performance After CAI
Old 08-08-2012, 09:25 PM   #12
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
What I Drive: '01 ZX3, '12 SE Sport
Points 1,806, Level 25
Points: 1,806, Level: 25 Points: 1,806, Level: 25 Points: 1,806, Level: 25
Level Up 6% Completed
FF Reputation: 12 TboneZX3 Great Standing Member
Originally Posted by craigsfocus View Post
I have a K&N Intake and I feel loss in power because of heat soak especially when its over 100 degrees and mine is shielded. My dyno sheet is proof of the heat soak. A few times its been in the mid 70's outside (it was 3am) and I felt a significant difference in power.
There are no tunes available for our Foci just yet.
Are you experiencing heat soak with your K&N only after sitting still for a while? The reason I ask is that the intake temp reported by the Torque app show within 6-8 degrees above ambient as long as I'm moving, even at low speeds. It does get higher than that fairly quickly at a full stop, but lowers again fairly quickly after I get moving. I'm sure the effect is greater than that of the stock intake by a fairly big margin (especially at 100 degree temps), but unfortunately I never used the Torque app while I had the stock intake.
HN #90
Mk3 |╠╬╝|SGM|203a|Moonroof|17" Paint/Mach Whls|K&N 57S-4000 -snorkel|FFE RMM|Steeda STB, RSB|JBR bushings
Mk1|╠╬╝|Pitch Blk|Prem pkg|Moonroof|SVT Snorkel|SVT Susp|Steeda STS|Z-Eng RMM|Magnaflow exh
TboneZX3 is offline
