Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 100,000+ Mileage Foci, Post here..
Old 08-08-2012, 01:05 PM   #869
NathanielCatch
Fan#: 102296
What I Drive: 2005 Ford Focus ZX4 S
Points 19, Level 1
Points: 19, Level: 1 Points: 19, Level: 1 Points: 19, Level: 1
Level Up 37% Completed
Level up: 37% Level up: 37% Level up: 37%
FF Reputation: 1 NathanielCatch Good Standing Member
Originally Posted by afraziaaaa View Post
Tank is fine. That will clean your fuel system out. Be sure to change the fuel filter soon after as all the crap gets caught in there. That can cause the fuel pump to gum up like mine did. There is a filter element (basically a mesh housing) that surrounds the fuel pump. Over time, debris will get caught in it and cause your fuel pump to fail. Better later than sooner.
You can also disconnect the vacuum line on the intake manifold and suck it up into the intake and cylinder head that way, although it bypasses the injectors and goes straight to the intake/valves to clean the carbon off. Also, try some in your engine next oil change.
Here is the video. I think I may have fixed the tick I heard but I think you are all correct in that the injectors and everything else just make a lot of noise anyway. Thanks for the help and you're welcome to others who may have this problem and this helped you.
YouTube Video
ERROR: If you can see this, then YouTube is down or you don't have Flash installed.
NathanielCatch is offline
